[Acr DC] Почему при изменении цвета текста слова
  • Автор темы Автор темы yuiop2017
Мда, разбиение на символы тут не поможет
текст уже разбит на блоки, примерно по строке в каждом
(use of two- and four-color line drawings, enhanced instruc-)
[5.26502 3.59496 4.52497 3.31403 5.26502 3.04503 3.31403 3.22493 6.93495 5.26503 3.78506 3.31403
4.33501 5.455 5.26501 3.31403 3.04504 5.26501 5.26501 3.43707 3.7851 4.33499 5.26501 2.67502
5.26501 3.78508 3.31403 2.675 2.67499 5.45502 4.52496 3.31403 5.26505 3.78506 4.33499 6.93497
2.67499 5.45499 5.08499 3.59494 2.48505 3.314 4.52499 5.45499 5.45499 4.33502 5.45499 4.33502
4.52496 5.26501 3.31403 2.67499 5.45502 3.59494 3.22495 3.78506 5.26501 4.33502 0 ]xsh
48.89 239.3 mo
(tor's tools, and new videos that all support and enhance the)
[3.22492 5.26503 3.78507 1.38803 3.59495 3.35002 3.22493 5.26503 5.26502 2.675 3.59496 2.48503
3.35002 4.33501 5.455 5.26503 3.35002 5.455 4.52496 6.93495 3.35002 4.52499 2.67499 5.26501
4.52499 5.26501 3.59496 3.35002 3.22495 5.45499 4.33499 3.22495 3.35004 4.33499 2.67499 2.67502
3.35001 3.59497 5.26501 5.26505 5.26501 5.26501 3.7851 3.22491 3.35004 4.33499 5.45502 5.26501
3.35004 4.52496 5.45499 5.45502 4.33499 5.45502 4.33499 4.52496 3.35004 3.22491 5.45502 0
]xsh
48.89 250.8 mo
(reader's experience.)
[3.78507 4.52498 4.335 5.26503 4.52497 3.78508 1.38802 3.59496 2.74403 4.52497 4.33501 5.26502
4.52498 3.78506 2.67502 4.52496 5.455 4.33501 4.52496 0 ]xsh
60.89 262.3 mo
(Our contributors are chosen for their expertise in the areas)
[8.17293 5.21302 3.73308 2.42203 4.283 5.21302 5.40299 3.17293 3.73308 2.623 5.21303 5.21303
3.17293 5.21303 3.73308 3.54294 2.42203 4.28302 3.73306 4.47298 2.42203 4.283 5.40298 5.21303
3.54295 4.47296 5.403 2.42203 2.99303 5.21301 3.73306 2.42203 3.17294 5.40298 4.47296 2.62302
3.73306 2.42203 4.47296 4.28302 5.21304 4.47296 3.73309 3.17291 2.62302 3.54297 4.47296 2.42203
2.62302 5.40302 2.42203 3.17291 5.40302 4.47296 2.42203 4.28302 3.73309 4.47296 4.28302 0
]xsh
Как видно из куска кода, строки даже во фреймы не объединены, акробат их формирует "на лету" по своему собственному усмотрению, исходя из координат символов :(
(use of two- and four-color line drawings, enhanced instruc-) [5.26502 3.59496 4.52497 3.31403 5.26502 3.04503 3.31403 3.22493 6.93495 5.26503 3.78506 3.31403 4.33501 5.455 5.26501 3.31403 3.04504 5.26501 5.26501 3.43707 3.7851 4.33499 5.26501 2.67502 5.26501 3.78508 3.31403 2.675 2.67499 5.45502 4.52496 3.31403 5.26505 3.78506 4.33499 6.93497 2.67499 5.45499 5.08499 3.59494 2.48505 3.314 4.52499 5.45499 5.45499 4.33502 5.45499 4.33502 4.52496 5.26501 3.31403 2.67499 5.45502 3.59494 3.22495 3.78506 5.26501 4.33502 0 ]xsh 48.89 239.3 mo (tor's tools, and new videos that all support and enhance the) [3.22492 5.26503 3.78507 1.38803 3.59495 3.35002 3.22493 5.26503 5.26502 2.675 3.59496 2.48503 3.35002 4.33501 5.455 5.26503 3.35002 5.455 4.52496 6.93495 3.35002 4.52499 2.67499 5.26501 4.52499 5.26501 3.59496 3.35002 3.22495 5.45499 4.33499 3.22495 3.35004 4.33499 2.67499 2.67502 3.35001 3.59497 5.26501 5.26505 5.26501 5.26501 3.7851 3.22491 3.35004 4.33499 5.45502 5.26501 3.35004 4.52496 5.45499 5.45502 4.33499 5.45502 4.33499 4.52496 3.35004 3.22491 5.45502 0 ]xsh 48.89 250.8 mo (reader's experience.) [3.78507 4.52498 4.335 5.26503 4.52497 3.78508 1.38802 3.59496 2.74403 4.52497 4.33501 5.26502 4.52498 3.78506 2.67502 4.52496 5.455 4.33501 4.52496 0 ]xsh 60.89 262.3 mo (Our contributors are chosen for their expertise in the areas) [8.17293 5.21302 3.73308 2.42203 4.283 5.21302 5.40299 3.17293 3.73308 2.623 5.21303 5.21303 3.17293 5.21303 3.73308 3.54294 2.42203 4.28302 3.73306 4.47298 2.42203 4.283 5.40298 5.21303 3.54295 4.47296 5.403 2.42203 2.99303 5.21301 3.73306 2.42203 3.17294 5.40298 4.47296 2.62302 3.73306 2.42203 4.47296 4.28302 5.21304 4.47296 3.73309 3.17291 2.62302 3.54297 4.47296 2.42203 2.62302 5.40302 2.42203 3.17291 5.40302 4.47296 2.42203 4.28302 3.73309 4.47296 4.28302 0 ]xsh
Нео, ты ли это?
Акробат 10 Pro вообще не хочет редактировать этот документ.
При попытке распознать текст пишет что нельзя этого сделать.
    502.7 КБ · Просм.: 743
    440 КБ · Просм.: 741
В XI все ok на этой странице
@_MBK_,
Да весь документ так. А как и что в 11 версии я знаю, только удалил её.:)
Похоже, что да, научился подобному только с десятки, да и то не до конца.
В восьмерке, к примеру, все текстовые блоки объединены в один Part разделить которые нельзя и выделяется только скопом:
Зато при подобной перекраске ничего никуда не слетает:
Зато, тачапом, как у Таси, получается нормально:
@_MBK_,
Не пойму, это плагин или опция в Акробат9?
Это штатный пункт меню восьмерки и девятки
А у вас разве нету?
@yuiop2017, посмотрите, справа должно быть дополнительное меню (чтобы тыц — и открывалась справа колонка с доп. инструментами).
@Aniriann, нету там такого, только обычные инструменты.
Всё нормально, конец моим мучениям'thank'
Почему цвета такие блеклые в Акробате 10?
Почему людей так много в Китае? '))'
В Японии! Вангую профиль японской газеты!
@yuiop2017, подскажите, 1) внедрен ли цветовой профиль в пдф? Какой внедрен?
2) При просмотре пдф с включенным Output Preview какой профиль указан в строке Simulation Profile?
Реакции: Jeine
