[CDR 2023] CorelDRAW 2023 Variable Outline Code Examples
  • Автор темы Автор темы dastin
dastin
Некромант-любитель
Posted 12-03-2023 at 14:47 by shelbym
Introduction
CorelDRAW 2023 has a new Variable Outline Tool. You can also apply a variable outline via code. :-) I have put together a number of VBA examples of how this works. Hopefully you will find these useful.
Sub TestAddVariableWidthNodes()
    Dim sLine As Shape
    Set sLine = ActiveLayer.CreateLineSegment(2, 8, 2, 5)
    sLine.Outline.VariableWidthNodes.Add 0.25, 0.125
    sLine.Outline.VariableWidthNodes.Add 0.5, 0.25
    sLine.Outline.VariableWidthNodes.Add 0.75, 0.125
End Sub
Sub TestClearVariableWidthNodes()
    Dim sLine As Shape
    sLine.Outline.VariableWidthNodes.Clear
End Sub
Sub TestCopyVariableWidthNodes()
    Dim sLine As Shape, sLine2 As Shape
    Set sLine2 = ActiveLayer.CreateLineSegment(4, 8, 4, 5)
    sLine2.Outline.VariableWidthNodes.Copy sLine.Outline.VariableWidthNodes
End Sub
Sub TestCountVariableWidthNodes()
    Dim sLine As Shape
    MsgBox “Number of variable width nodes: “ & sLine.Outline.VariableWidthNodes.Count, , “Variable Width Nodes”
End Sub
Sub TestSelectedVariableWidthNodes()
    Dim sLine As Shape
    Dim vwNode1 As IVGVariableWidthNode, vwNode2 As IVGVariableWidthNode, vwNode3 As IVGVariableWidthNode
    Set vwNode1 = sLine.Outline.VariableWidthNodes.Add(0.25, 0.125)
    Set vwNode2 = sLine.Outline.VariableWidthNodes.Add(0.5, 0.25)
    Set vwNode3 = sLine.Outline.VariableWidthNodes.Add(0.75, 0.125)
    vwNode2.Selected = True
End Sub
Sub TestSidesVariableWidthNodes()
    Dim sLine As Shape
    vwNode1.Side1Width = 0.25
    vwNode3.Side2Width = 0.25
End Sub
Sub TestDeleteVariableWidthNodes()
    Dim sLine As Shape
    vwNode2.Delete
End Sub
Sub TestMoveVariableWidthNodes()
    Dim sLine As Shape
    vwNode1.PositionT = 0.125
    vwNode3.PositionT = 0.875
End Sub
Sub TestDetialsVariableWidthNodes()
    Dim sLine As Shape
    Dim strDetails As String
    vwNode1.Selected = True
    For i = 1 To sLine.Outline.VariableWidthNodes.Count
        strDetails = strDetails & i & “: “ & sLine.Outline.VariableWidthNodes(i).Width & “ Pos: “ & sLine.Outline.VariableWidthNodes(i).PositionT & “ Sel: “ & sLine.Outline.VariableWidthNodes(i).Selected & “ S1: “ & sLine.Outline.VariableWidthNodes(i).Side1Width & “ S2: “ & sLine.Outline.VariableWidthNodes(i).Side2Width & “ Width: “ & sLine.Outline.VariableWidthNodes(i).Width & vbNewLine
    Next i
    MsgBox strDetails, , “Variable Width Nodes”
End Sub
Conclusion
Have some fun coding Variable Outlines. :-)
Реакции: izrukvruki и DukereD
Вот как выглядит нововведение
- новым инструментом Variable Outline Tool. добавляется контрольная точка
- сдвигом маркера управления меняется толщина контура
Окно Outline Pen теперь выглядит следующим образом
Вид Panel Properties при активном Variable Outline Tool ( V )
