Чем отличается спектрофотометр i1pro2 от Efi и от X-Rite
  • Автор темы Автор темы VaganG6
  • Теги Теги
    i1pro2
Реакции: VaganG6
Человек скинул мне вот это:
i1Pro Tests
General Information
Date and Time: 13.03.2023 22:03:42
Application version: 4.1.2.290, 32-bit
SDK version i1Pro: 4.2.3.4987
SDK version i1iO: 2.2.3.4987
SDK version i1iSis: 2.0.0.4968
SDK version ColorMunki: 1.0.3.4630
SDK version i1Display2: X-Rite, Inc. SipCal Library Ver. 7.3.7 (32 bit)
Platform: Microsoft Windows 8.1, 64-bit
Open instrument
Connection: Successful
Open instrument: Successful
Instrument information
Instrument inspection: Successful
Serial number i1Pro: 7075423
Type: i1Pro
Revision: E
Firmware version: 634
CPLD version: 999
Dark measurement count: 1374
Lamp burning time: 127.6 seconds
Spot measurement count: 37
Scan measurement count: 24
Factory calibration: 16.05.2018
Spectral Module ID: 01-9846351a0000b1
Supplier: 'EFI-ES2000'
Warranty start date: 09.10.2019 18:23:00
Recertification date: -
Instrument Licenses
Measurement Modes: [Reflectance Spot, Reflectance Scan, Emission, DualReflectance Spot, DualReflectance Scan]
Licensed functionality: [Has UV LED, Has Wavelength LED, Has Zebra Ruler sensor, Max Ruler Length = 300 mm, Has Indicator LED, Spectral values, Tristimulus, Density]
Licensed Modules:
i1Match Module "Scanner": NOT licensed
i1Match Module "Monitor": licensed
i1Match Module "Printer": NOT licensed
i1Match Module "Printer RGB only": NOT licensed
i1Match Module "Printer CMYK only": NOT licensed
i1Match Module "Beamer": NOT licensed
i1Match Module "Printer Easy RGB": NOT licensed
i1Match Module "Printer Easy CMYK": NOT licensed
i1Match Module "Digicam": NOT licensed
i1Match Module "Editor": NOT licensed
i1Profiler Module "Display Profiling": NOT licensed
i1Profiler Module "RGB Printer Profiling": NOT licensed
i1Profiler Module "CMYK Printer Profiling": NOT licensed
i1Profiler Module "Printer QA": NOT licensed
i1Profiler Module "Advanced-Mode": NOT licensed
i1Profiler Module "Projector": NOT licensed
Button test
Button: Successful
Emission test
Emission calibration: Successful
Prepare the instrument for emission measurement
White measurement: Successful
Gray measurement: Successful
Black measurement: Successful
Red measurement: Successful
Green measurement: Successful
Blue measurement: Successful
Emission: Successful
Button test
Button: Fail (Timeout)
Tip:
Press the measurement button on your i1Pro.
Repeating test...
Button test
Button: Successful
Noise Tests
Noise measurements: Successful
Noise result: Successful
Reflectance test
Reflectance Spot calibration: Successful
Reflectance Spot measurement 1: Successful
Reflectance Spot measurement 2: Successful
Reflectance Spot measurement 3: Successful
Reflectance Spot measurement 4: Successful
Reflectance Spot measurement 5: Successful
Reflectance Spot measurement 6: Successful
Reflectance Spot measurement 7: Successful
Reflectance Spot measurement 8: Successful
Reflectance Spot measurement 9: Successful
Reflectance Spot measurement 10: Successful
Lamp test: Successful
Reflectance drift test: Successful
Reflectance Scan calibration: Successful
Dual Reflectance Spot calibration: Successful
Dual Reflectance Spot test: Successful
Dual Reflectance Scan calibration: Successful
Positioning Sensor Test
Scan with positioning sensors: Fail (Aborted)
*** ABORT ***
Что можете сказать по этим данным, стоит брать за 70 тысяч? Говорит новый(
"i1Match Module "Monitor": licensed"
Используя "честную версию" i1Profiler вы сможете настраивать только мониторы.
Измерять тест шкалы у принтеров вы тоже сможете, но на построение профайла в i1Profiler нет лицензии.
Реакции: VaganG6
У меня вопрос, почему айван диагностик видит его как айван 1 про (без 2)
Потому что для программы это один и тот же прибор. Но программа указывает его ревизию. Rev.E - это i1Pro2.
Реакции: VaganG6 и mihas
    310 КБ · Просм.: 233
Реакции: VaganG6
Прошу имевших дело с приборами i1Pro 2, брендированными EFI, подтвердить или опровергнуть: приборы распознаются и позволяют проводить M0/M1/M2 сканирование в i1Profiler?
Отличаются только вшитыми лицензиями на xrite-овский софт. Измерительный функционал и поддержка софтом полностью идентичны. Да, чуть не забыл - в приборах EFI отсутствует светоизмерительная голова. Всё.
Реакции: koraalex
Он (ES2000) опознаётся виндой как i1Pro. В диспетчере устройств.
Дрова от i1Pro2 с сайта x-rite ставятся.
На пузе у него сказано что он i1pro2
В i1Profiller работает точно так же как i1Pro2.
Свет не умеет измерять. Это так.
У меня на руках es2000
Реакции: koraalex
1000 EFI мне попадались только для М2 - на них на крышке апертуры так и было написано UV. С 2000 дела не имел - не знаю. Но проверить стоит наверное.
Реакции: koraalex
...в приборах EFI отсутствует светоизмерительная голова.
Но если эта насадка имеется (у меня от старого прибора), то спектр освещения без проблем можно измерять например при помощи Argyll.
Реакции: koraalex
Подтверждаю. ES2000, в комплекте доска для сканирования (не нахожу лучшего термина) отпечатков и мешок для закидывания за спину монитора. Головы для рассеяного света нет. DisplayCAL распознает как i1Pro2, последняя версия iProfiler работает. На пузе i1Pro rev. E.
Распознаются и дают сканировать (в два прохода на каждый ряд), я получил на выходе три набора файлов вместо одного (сохранял в формате ProfileMaker), скормил их BasicColor Print, построил по всем трем профиль принтера. Сильно не всматривался, но по всем трем плюс-минус одни и те же значения. Вроде построил корректно, за исключением нюансов с выбором типа бумаги, но это я уже сам спрошу в другой теме. Буду признателен, если скажете зачем это :)
Реакции: koraalex
"spotread -a" работает? У прибора может отсутствовать режим Ambient (проверяется в i1Diagnostics), Argyll такие вещи понимает (прибор, надо полагать, работает в Emission (-e) и в Projector (-p), отличие Ambient только в заложенном в прибор пересчёте в люмены, который действительно может быть разным для разных молочных стёкол; строго говоря может быть и небольшая коррекция спектра, - не проверял).
