Available exclusively to subscribers and licensees with an active CorelSure Maintenance plan,
the CorelDRAW® Graphics Suite June 2023 Update (v24.4) delivers enhancements, and performance and stability improvements.
The June 2023 Update can only be applied to CorelDRAW Graphics Suite with the March 2023 Update and Hot Fix 1 (v24.3.1).
Released: 06-27-2023
Загрузить
да ... ещё одна деталь ... возможно важная - русского языка в перечне нет (прежде был) - неведомо как скажется для приложения использующего русский интерфейс
New and enhanced features
The CorelDRAW® Graphics Suite June 2023 Update (v24.4) delivers enhancements to several areas within the applications:NEW! Onyx Graphics color palettes
With the latest update, the Onyx Graphics color palettes are now integrated into CorelDRAW Graphics Suite, allowing you to incorporate these color palettes into your production workflows with ease.ENHANCED! Import files with object styles
In CorelDRAW, when you import files that have object styles with identical names to those in your drawing, you can now choose from the following options:- Import and rename the styles.
- Replace the imported styles with the styles in the active document.
- Replace the styles in the active document with the imported styles.
- Import the content without the styles.
ENHANCED! Template preview performance
Switching between local templates and Corel online templates on the Templates tab of the Create a New Document dialog box (File > New from Template) in CorelDRAW is now faster and more seamless than ever, with thumbnails appearing instantly in the preview pane. In the case of any delay, a message informs you that the assets are still loading, and temporary placeholder images are displayed until the thumbnails have fully loaded.Performance and Stability
CorelDRAW Graphics Suite June 2023 Update (v24.4) also includes performance and stability fixes for several customer-reported issues.- When importing or opening a PDF file in CorelDRAW, fountain fills display with the expected gradient settings.
- When opening a document with over 3000 object styles, you now have the option to remove the unused styles if 100 or more of them are not in use.
- Italicized text is no longer cut off for fonts that have a bold or thick appearance.
- When modifying the width and height settings and enabling the Crop to page on export option in the Export for Web dialog box accessed from the Export docker (Windows) or Export inspector (macOS), the changes are now retained for future access.
- Drop shadows, block shadows, or contours applied to print merge fields function as expected when previewing and printing a merge document in CorelDRAW or saving it to a new document.
- You can now quickly save CorelDRAW documents that contain nested symbols and export them to the CMX format. Additionally, you can open the exported CMX files in CorelDRAW without any issues.
- When a color applied to an object contains a tab character in its name, and the CorelDRAW document is exported to the PDF format, the resulting PDF no longer generates an 'Unrecognized object name' error when opened in Adobe Acrobat.
- Continuous curves in shapes are smooth and retain the correct number of nodes when a CorelDRAW document is exported to the DWG or DXF format by using the Export curves as splines option.
- Now when you export a CorelDRAW document that contains text using an OCR font to the DWG format, and then import the DWG file back into CorelDRAW, the OCR fonts are preserved.
- Adding folders with high activity to the list of monitored folders no longer causes Corel Font Manager to hang and freeze at 'Analyzing 0%'.
- Alpha channels in raster images are now retained and are no longer inserted in PowerClip frames when you export a CorelDRAW document to the SVG format.
- When exporting sliced images in Corel PHOTO-PAINT™ (File > Export to Web), the exported image filenames now include the original filename and a distinct identifier assigned to each slice.
- The Welcome Screen displays as expected when resizing the CorelDRAW or Corel PHOTO-PAINT application window.
- Issues with auto-backup when closing documents or quitting CorelDRAW on Windows have been resolved.
- CorelDRAW on Windows no longer becomes unresponsive when auto-backup is triggered during the process of adjusting and applying settings in the Print dialog box, previewing your work in the Print Preview dialog box, and then closing Print Preview.
- Stability issues related to closing, saving, or exporting CDR files containing bulleted text have been resolved.
- CorelDRAW no longer stops responding after you apply a fountain fill with one or more transparent nodes to a vector object or import PDF content with object transparency into a drawing, and then export the drawing to a bitmap format by choosing the Grayscale (8-bit) color mode.
- Applying a custom media stroke when using the Sprayer mode of the Artistic Media tool and then choosing another custom media stroke or changing to Brush mode no longer causes CorelDRAW to stop responding.
- Converting objects to grayscale bitmaps in CorelDRAW (Bitmaps > Convert to Bitmap > Grayscale (8-bit)) no longer causes the application to stop responding.
- CorelDRAW on Windows no longer stops responding after you enter Chinese text by using a third-party Input Method Editor (specifically, "中文(简体) - 万能五笔输入法," a Chinese Simplified Universal five-stroke input method) and quit the application.
- Several issues that caused applications to stop responding have been addressed.
Загрузить
Languages:
- English
- Čeština
- Deutsch
- Español
- Français
- Italiano
- Nederlands
- Svenska
- Polski
- Português do Brasil
- Türkçe
- 日本語
- 简体中文
- 繁體中文
