[Продам] Продам X-Rite i1 Pro2 (EFI ES2000)
  • Автор темы Автор темы avs60
avs60
35 тыс. руб. Отправлю ТК/Почта и пр. СДЕК.
Минимальные жизненные потёртости никак не влияющие на работу.
i1Pro Tests
General Information
Date and Time: 2019-01-22T12:06:12
Application version: 4.1.2.290, 32-bit
SDK version i1Pro: 4.2.3.4987
SDK version i1iO: 2.2.3.4987
SDK version i1iSis: 2.0.0.4968
SDK version ColorMunki: 1.0.3.4630
SDK version i1Display2: X-Rite, Inc. SipCal Library Ver. 7.3.7 (32 bit)
Platform: Microsoft Windows 7 Service Pack 1 (Build 7601), 64-bit
Instrument information
Instrument inspection: Successful
Serial number i1Pro: 7012934
Type: i1Pro
Revision: E
Firmware version: 634
CPLD version: 999
Dark measurement count: 28989
Lamp burning time: 30711.6 seconds
Spot measurement count: 4305
Scan measurement count: 7007
Factory calibration: 2013-05-23
Spectral Module ID: 01-28c3e1150000ff
Supplier: 'EFI-ES2000'
Warranty start date: 2013-09-30T18:45:36
Recertification date: -
Instrument Licences
Measurement Modes: [ReflectanceSpot, ReflectanceScan, EmissionSpot, DualReflectanceSpot, DualReflectanceScan]
Licensed functionality: [Has UV LED, Has Wavelength LED, Has Zebra Ruler sensor, Max Ruler Length = 300 mm, Has Indicator LED, Spectral values, Tristimulus, Density]
Licensed Modules:
i1Match Module "Scanner": NOT licensed
i1Match Module "Monitor": licensed
i1Match Module "Printer": NOT licensed
i1Match Module "Printer RGB only": NOT licensed
i1Match Module "Printer CMYK only": NOT licensed
i1Match Module "Beamer": NOT licensed
i1Match Module "Printer Easy RGB": NOT licensed
i1Match Module "Printer Easy CMYK": NOT licensed
i1Match Module "Digicam": NOT licensed
i1Match Module "Editor": NOT licensed
i1Profiler Module "Display Profiling": NOT licensed
i1Profiler Module "RGB Printer Profiling": NOT licensed
i1Profiler Module "CMYK Printer Profiling": NOT licensed
i1Profiler Module "Printer QA": NOT licensed
i1Profiler Module "Advanced-Mode": NOT licensed
i1Profiler Module "Projector": NOT licensed
Button Test
Button: Successful
Emission test
Emission calibration: Successful
Prepare the instrument for emission measurement
White measurement: Successful (X=71.091 Y=74.443 Z=76.465)
Gray measurement: Successful (X=25.421 Y=26.552 Z=28.528)
Black measurement: Successful (X=0.121 Y=0.141 Z=0.210)
Red measurement: Successful (X=44.816 Y=20.847 Z=0.742)
Green measurement: Successful (X=10.110 Y=33.704 Z=5.342)
Blue measurement: Successful (X=12.021 Y=4.837 Z=62.447)
Emission: Successful
Button Test
Button: Successful
Noise Tests
Noise measurements: Successful
Noise result: Successful (electronic noise: 3.122)
Reflectance test
Reflectance Spot calibration: Successful (slope=0.0137199294 (0.150000006), WLS=0.150000006)
Reflectance Spot measurement 1: Successful (96.136, -0.419, 2.078)
Reflectance Spot measurement 2: Successful (96.122, -0.422, 2.081)
Reflectance Spot measurement 3: Successful (96.115, -0.423, 2.082)
Reflectance Spot measurement 4: Successful (96.111, -0.419, 2.079)
Reflectance Spot measurement 5: Successful (96.108, -0.419, 2.082)
Reflectance Spot measurement 6: Successful (96.111, -0.429, 2.093)
Reflectance Spot measurement 7: Successful (96.110, -0.415, 2.087)
Reflectance Spot measurement 8: Successful (96.108, -0.420, 2.090)
Reflectance Spot measurement 9: Successful (96.106, -0.423, 2.083)
Reflectance Spot measurement 10: Successful (96.107, -0.417, 2.082)
Lamp test: Successful (minL=96.106 meanL=96.113 MIT=0.0148637658 CIT=0.0114839999 LOT=30715.7129)
Reflectance drift test: Successful (0.009)
Reflectance Scan calibration: Successful (slope=0.0137199294 (0.150000006), WLS=0.150000006)
Dual Reflectance Spot calibration: Successful (slope=0.0137199294 (0.150000006), WLS=0.200000003)
Dual Reflectance Spot test: Successful
Dual Reflectance Scan calibration: Successful (WLS=0.200000003)
Positioning Sensor Test
Scan with positioning sensors: Successful (min: 0.000, max: 0.261, total distance: 0.261)
Личка, майл, скайп - не часто захожу.
Александр. Новосибирск.
    111 КБ · Просм.: 680
    110.9 КБ · Просм.: 693
    65.3 КБ · Просм.: 709
Приборчик Treid-In? Т.е. от X-Rite была скидка в зачет покупки нового прибочика и забанивания номера 7012934 в их базе?
Пардон... " Вам шашечки или ехать?" (с) Прибор интересует или воздуся сотрясать?
Касаемо вопроса - без понятия о чём речь.
Продан.
