Поживёт ещё?
  • Автор темы Автор темы ~RA~
~RA~
Одарённая истеричка.
Как думаете? Или под помойку?
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Barracuda 7200.14 (AF)
Device Model:     ST2000DM001-9YN164
Serial Number:    скрыт
LU WWN Device Id: 5 000c50 04e77fabc
Firmware Version: CC4H
User Capacity:    2 000 398 934 016 bytes [2,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri Sep  4 14:08:06 2020 MSK
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Unavailable
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (  575) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 216) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x3085)    SCT Status supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   119   100   006    -    216732392
  3 Spin_Up_Time            PO----   095   094   000    -    0
  4 Start_Stop_Count        -O--CK   093   093   020    -    7788
  5 Reallocated_Sector_Ct   PO--CK   100   100   036    -    0
  7 Seek_Error_Rate         POSR--   076   060   030    -    44263235
  9 Power_On_Hours          -O--CK   062   062   000    -    33532
10 Spin_Retry_Count        PO--C-   100   100   097    -    0
12 Power_Cycle_Count       -O--CK   100   100   020    -    12
183 Runtime_Bad_Block       -O--CK   100   100   000    -    0
184 End-to-End_Error        -O--CK   100   100   099    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   100   000    -    0 0 0
189 High_Fly_Writes         -O-RCK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   068   054   045    -    32 (Min/Max 26/32)
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    0
192 Power-Off_Retract_Count -O--CK   100   100   000    -    7
193 Load_Cycle_Count        -O--CK   001   001   000    -    726896
194 Temperature_Celsius     -O---K   032   046   000    -    32 (0 18 0 0 0)
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
240 Head_Flying_Hours       ------   100   253   000    -    26094h+42m+53.767s
241 Total_LBAs_Written      ------   100   253   000    -    7950359066956
242 Total_LBAs_Read         ------   100   253   000    -    133006035847697
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS      20  Device vendor specific log
0xa2       GPL     VS    4496  Device vendor specific log
0xa8       GPL,SL  VS      20  Device vendor specific log
0xa9       GPL,SL  VS       1  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xb0       GPL     VS    5067  Device vendor specific log
0xbd       GPL     VS     512  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    31 Celsius
Power Cycle Min/Max Temperature:     26/31 Celsius
Lifetime    Min/Max Temperature:     18/45 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            6  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
                    been run.
                    command.
                    power-saving mode.
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Поживет. Я ничего критичного не вижу кроме 4-х лет использования
Отформатировал, стало так:
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       8
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       8
Погоняю сейчас и посмотрю, не продолжится ли рост.
Я человек простой, в смартах не разбираюсь... Обычно запускаю тест поверхности диска и если график ровно-убывающий и без сильных провалов по времени чтения, то все ок.
Ну как было по нулям нестабильных секторов и невосстанвимых ошибок, так и осталось :) Форматирование само по себе ничего не выявит, нужно тест чтение-запись всей поверхности прогнать, после посмотреть где провалы и насколько большие и не изменилось ли что в смарте. Повторно прогнать те участки где были большие провалы, если картина повторяется, вероятность что скоро будут кандидаты на замену возрастает.
Ну я не совсем идиот. ;) Смысл фразы
был в том, что совсем у небольшому количеству секторов успел обратиться и на тебе!
уже гоню ;)
Checking blocks 0 to 1953514583
Checking for bad blocks (read-only test): y  0.03% done, 0:03 elapsed. (0/0/0 errors)
39847788done, 3:56 elapsed. (0/0/0 errors)
39847789done, 3:59 elapsed. (1/0/0 errors)
39847790done, 4:02 elapsed. (2/0/0 errors)
39847791done, 4:04 elapsed. (3/0/0 errors)
Понглядее будет.
Имхо -- под помойку.
Абсолютно неинформативный показатель ИМХО
Информативный, просто его читать надо уметь.
Там 2 первых байта одно кажут, а 4 других другое, а вместе, да приведённые к инту — ужосужос.
Я к тому, что сам по себе параметр смысл имеет, но судить по нему о здравии диска сложно. Как если записать в одну ячейку рост и вес. Смысл есть, но о здравии само по себе это говорит мало.
Да я бы прогнал его фирменной утилитой и пользовался под временные данные.
У меня такой внешний 500 WD в корпусе от зонтичного Prestigio.
Умершие порядка 85 МБт.
Помеченые запретом от записи.
Как медиа хранилище к приставке под сериальчики.
Жмутся все, экономят '))' но вообще-то накаркали гады у меня вот тоже сегодня комп пару раз завис наглухо. Наверное старенький ссд под кэш сдыхает.
Погонял, теперь какое кажет:
Local Time is:    Sat Sep  5 12:16:42 2020 MSK
Self-test execution status:      ( 121)    The previous self-test completed having
                    the read element of the test failed.
                    command.
                    power-saving mode.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   097   088   006    Pre-fail  Always       -       204675192
  3 Spin_Up_Time            0x0003   095   094   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   093   093   020    Old_age   Always       -       7790
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       1048
  7 Seek_Error_Rate         0x000f   076   060   030    Pre-fail  Always       -       44286293
  9 Power_On_Hours          0x0032   062   062   000    Old_age   Always       -       33553
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       14
183 Runtime_Bad_Block       0x0032   099   099   000    Old_age   Always       -       1
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   001   001   000    Old_age   Always       -       1851
188 Command_Timeout         0x0032   099   099   000    Old_age   Always       -       0 1 1
189 High_Fly_Writes         0x003a   050   050   000    Old_age   Always       -       50
190 Airflow_Temperature_Cel 0x0022   064   054   045    Old_age   Always       -       36 (Min/Max 36/37)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       8
193 Load_Cycle_Count        0x0032   001   001   000    Old_age   Always       -       726898
194 Temperature_Celsius     0x0022   036   046   000    Old_age   Always       -       36 (0 18 0 0 0)
197 Current_Pending_Sector  0x0012   081   081   000    Old_age   Always       -       3248
198 Offline_Uncorrectable   0x0010   081   081   000    Old_age   Offline      -       3248
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       26116h+35m+42.131s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       7978480434130
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       133160204082498
Жаль винт :( под офлайн хранилище восстановимой информации (то, что можно скачать из интернета например) максимум. Хотя и не понятно с чего вдруг он начал сыпаться....
А какая у него история? Работал до последнего времени или лежал год на полке? В чем работал?
