Кому-то знаком этот фильтр?
  • Автор темы Автор темы AlexHH
AlexHH
Приветствую всех! Не подскажете фильтр, применённый на этом изображении?
    163 КБ · Просм.: 162
GPT говорит. Многие шаги похожи на правду. Можете пробовать.
(Но выглядит очень дешево имо)
"Engraved/Illustrated Leaf" Effect in Photoshop
1. Desaturate the Image (Black & White)
  • Go to Image > Adjustments > Black & White or press Shift+Ctrl+Alt+B.
  • Adjust sliders to enhance contrast between veins and edges of the leaf.
2. Duplicate the Layer
  • Right-click on the layer in the Layers Panel and choose Duplicate Layer.
  • Work on the duplicated layer.
3. Apply High Pass Filter
  • Go to Filter > Other > High Pass.
  • Use a Radius around 2 to 5 pixels, depending on the resolution.
  • This sharpens edges and gives the embossed vibe.
4. Add Embossing (Optional)
  • Go to Filter > Stylize > Emboss.
  • Set:
    • Angle: ~135°
    • Height: 2-3 px
    • Amount: Adjust to get that carved effect.
  • Set this layer’s blending mode to Overlay or Soft Light.
5. Enhance the Lines (Use Poster Edges or Find Edges)
  • Go to Filter Gallery > Artistic > Poster Edges
    • Edge Thickness: ~7
    • Edge Intensity: ~1
    • Posterization: ~2
  • OR try Filter > Stylize > Find Edges, then invert (Ctrl+I) and blend.
6. Adjust Contrast with Curves or Levels
  • Image > Adjustments > Levels or Curves
  • Deepen shadows and brighten highlights to get that high-contrast, etched look.
7. Optional: Liquify or Oil Paint for Swirl Texture
  • Try Filter > Stylize > Oil Paint
    • Stylization: 2–3
    • Cleanliness: 4–6
    • Scale: 0.5–1.5
    • Bristle Detail: 0–2
  • This adds a subtle smooth, swirly texture like your image.
💡 Final Touch​
  • Consider adding a black background layer to enhance the contrast of the leaf outlines.
  • Sharpen final image slightly: Filter > Sharpen > Unsharp Mask.
По-моему это просто Oil Paint Filter
ЗЫ Сорри, не дочитал до конца ответ)
  • Set:
    • Angle: ~135°
    • Height: 2-3 px
    • Posterization: ~2
    • Stylization: 2–3
    • Cleanliness: 4–6
    • Scale: 0.5–1.5
💡 Final Touch​
Спасибо! Достаточно информативно. Будем экспериментировать.
ИМХО, oil Paint без особых премудростей
Нашёл онлайн демку - XDoG Sketch. Но там параметр Thresold не регулируется.
Похоже только внутри контуров - в оригинале контур довольно неточно обведен белой линией.
Здесь больше похоже на работу с уровнями и контрастом + резкость.
Давно уже использовал фильтр (названия не помню), который превращал изображение в огненное. Типа, огненный конь. Регулируя уровень пламени (размер), можно при минимальных значениях приблизиться к искомому. Меня терзают смутные сомнения, что я недалёк от истины ÷)
Извиняюсь. Не xDoG, а FxDoG. Эта картинка с белочкой отсюда. Онлайн демо там уже не работает, но есть такое. Я поэксперементировал с этим алгоритмом и вот, что получилось:
Белка это та же крыса с более удачным дизайном и маркетингом
Весьма похоже на g'mic (pencil), хотя круче, конечно.
Вот что можно выжать из g'mic:
Картинка 600 px (размер важен). Грызун отдельным слоем, выделен очень грубо волшебной палкой. Два слоя потому, что фильтр одинаково воздействует и на грызуна и на фон. Очень шумно получается. Грызун подвергался фильтру дважды.
А зачем ОР эта радость вообще нужна?
